Author Topic: Time to update the RM  (Read 22657 times)
Offline MetalMike1982
« Reply #30 on: May 29, 2012, 11:37:16 PM »
will a 3$ NGK not work? we run them in all of our bikes and they work just fine
 suzuki says the $30 plug is the only plug recommended for my bike , and If I run a different plug I run the risk of grenadeing my topend.  If I had to change plugs all the time I would be seriously bitching and probably buying cheap $3 plugs but It dosent foul plugs anymore after I jetted/adjusted the carb.
Offline twosmoke595
« Reply #31 on: May 30, 2012, 12:12:41 AM »
hmm well i haven't fouled a single plug on my 125, and i fouled 2 plugs on my yz250 because when i first got it it jetted for too lean of a gas mixture and when we jetted it for 32:1 it was perfect haven't fouled one since, all on 3$ NGK plugs
« Reply #32 on: May 30, 2012, 12:52:25 AM »
Yeah man, I run $6 NGK's in my 250 and I have not fouled one (knock on wood  ;) ) Yet.
Recovered
  • Guest
« Reply #33 on: May 30, 2012, 01:36:57 AM »
whats the part number?
basically the gimmick going right now is the iridium does not conduct better, but is stronger, therefore the electrode can be smaller, which means less resistance.  it's just more expensive.  the gimmick with platinum is that it has a cleaning property when charged.  good for cars these days that have the engine up under the dashboard.  but the best conductor is still copper as far as electrode material.
i suppose you could grab a couple copper ones to get the thing jetted, then run the 30 dollar iridium one once everything is sorted.  that's probably what i'd do.
« Reply #34 on: May 30, 2012, 07:48:27 AM »
I used to run standard BR8's in my 01 rm250 with no problems.
Don't know if the 03 is different
Recovered
  • Guest
« Reply #35 on: May 30, 2012, 12:51:49 PM »
That's what's in my KTM right now.  a BR8eg i believe it is.
Offline motoman356
« Reply #36 on: May 30, 2012, 07:27:01 PM »
no the rm125 had a special made plug to run with the bike. i've tried others but the bike didnt run well. i wouldnt stray from from it despite the higher cost. and as far as fouling i never had an issue even when i was slower.
« Reply #37 on: May 31, 2012, 12:43:36 AM »
 When I was jetting it I used cheap plugs and then what I got it right I put in the "special" plug . So basically what Premixed said is what I already did .  The part number is R6918b-8
