Author Topic: RM 250 Fork question  (Read 15296 times)
Offline 2stroke250
« on: May 25, 2010, 04:26:35 PM »
Hey guys I have a question. This is my 96 RM 250. I have a seal leak on the right side of the fork. I know that stock 96 forks were inverted from what I have, but I need to replace the seals. I'm not totally sure what kind of forks I have on there. I took the plastic off so you guys could have a better view. I have updated plastics and engine in there, so I swear it's not a 99 or 00 bike. I just need to know what year forks I have if not aftermarket. Thanks
1996 SUZUKI RM250 W/2000 RM250 ENGINE SWAP
Offline 2stroke250
Re: RM 250 Fork question
« Reply #1 on: May 25, 2010, 04:28:29 PM »
Also, what weight fork oil should I use? I just trail ride. Are those fork relief valves worth getting too?
Offline graham472
« Reply #2 on: May 25, 2010, 05:39:52 PM »
They're Kayaba forks and I'd say from a 2003 model, actually I'd say the whole front end is going by the brakes.
5w oil. I think the fork bleeders are a good idea, saves needing a screwdriver.
« Last Edit: May 25, 2010, 05:43:02 PM by graham472 »
Offline RedFoxCR
« Reply #3 on: May 25, 2010, 10:27:35 PM »
Hey. You wanna say those marks on the fork legs, it's a leak??? You sure??? Crap, i have those, too!!!! :( You sure it isn't a moisturizing option???
Neytiri:Now you choose your CR 500R. This you must
feel - inside.If he also chooses you,move quick, like I showed.You will have one chance, Jake.
Jake:How will I know if he chooses me?
Neytiri:He will try to kill you.
Jake: Outstanding.
Offline 2stroke250
« Reply #4 on: May 26, 2010, 04:21:01 AM »
Thanks Graham472. I only found a couple of numbers on the forks. At the bottom on the inside of the fork there is a 271-P on one side, and a 271-L on the other. I looked on the inside of the white plastic fork cover which was designed for 01,02,03,04 models. RedfoxCR, I think it is a leak because I only get an oily residue buildup on one side.
