Author Topic: eric gore 265 kits  (Read 9616 times)
Offline vetman
eric gore 265 kits
« on: January 14, 2013, 02:09:41 AM »
Hi there has anyone out there used one of erics 265 kits,i know he is the guru when it comes to our great two smokers more wondering if there is a noticable power increase and longgevity of the kit any help would be great cheers
Offline luthier269
eric gore 265 kits
« Reply #1 on: January 14, 2013, 03:19:57 AM »
Call Eric he ansers the phone and will anser your questions he is real friendly. We have a 134 big bore and have had no problems and it runs great!
eric gore 265 kits
« Reply #2 on: January 15, 2013, 03:52:04 AM »
the extra 15cc doesn't offer much more grunt, its the porting that does ;)
unless your cylinder is damaged you would be much better off spending your money on a professionally made cone pipe... both will cost roughly the same.
Then at some point in the future if you've got a damaged bore, the 265's are a great piece of kit
eric gore 265 kits
« Reply #3 on: January 15, 2013, 05:50:32 AM »
This. The 15ccs isn't what makes people big bore their 250s, its the powerband that is bred from the change in capacity.
MXA 270ed their 08 YZ250 and they reckon it was the ducks nuts in terms of a powerband. Lets face it, a YZ250 powerband is almost fourstroke like at the best of times but apparently it was really awesome.
Offline vetman
eric gore 265 kits
« Reply #4 on: January 15, 2013, 06:18:58 AM »
cheers guys thought about pipes but for my tm the only after market one is a scalvani which are super bling.would love to get a fmf fatty but still being a little exotic none available just trying to get a boost over the whole rev range cheers
eric gore 265 kits
« Reply #5 on: January 15, 2013, 06:57:04 AM »
Don't bother with big bore kits for the TM.
Best mods you can do is get the head machined to improve the squish band and remove the air boot and match it to the manifold. ( the fitment is not so good from factory).
That will make the powerband smoother.
If then you still think the hit is too big fit a JRF Torque controller.
What year is your bike ?
eric gore 265 kits
« Reply #6 on: January 15, 2013, 10:13:34 AM »
Over bores reduce the exhaust port duration something you can do to any cylinder by machining off the base.
eric gore 265 kits
« Reply #7 on: January 15, 2013, 11:21:25 AM »
If its a TM250, then I wouldnt touch it.
Id be setting up the head as stated and the torque controller
Offline vetman
eric gore 265 kits
« Reply #8 on: January 15, 2013, 07:36:19 PM »
had been looking into a stage 1 port on the barrel the crankcases are polished factory anyway the squish was the next step, was going to leave all alone as i was going to get a 013 300mx but finances have stopped that at the mo so ill give my 011 a tickle up and wait a year have worked on the set up and sus and now a full tm convert but still finding im getting eaten up a little by 450s which unortunately is just down to horsepower so in my eyes any little bit helps
eric gore 265 kits
« Reply #9 on: January 16, 2013, 06:26:48 AM »
Is your bike a 250 or 300.?
Offline vetman
eric gore 265 kits
« Reply #10 on: January 16, 2013, 06:32:14 AM »
250 was only available when i bought few jitters, knew about them just never seen one in the flesh stoked i bought, but a year and a bit on here i am
eric gore 265 kits
« Reply #11 on: January 16, 2013, 06:56:14 AM »
You will always struggle against 450's with a 250.
Best thing you can do is what I said above.
Even though they have good engine's , there is a little more available if you set the squish and fix the airboot issue.
You have a good reliable bike. ;D
Offline vetman
eric gore 265 kits
« Reply #12 on: January 16, 2013, 07:08:29 AM »
had the barrel off to do a ring anyway spent the arvo polishing the exhaust port will do the squish while im here  but cheers for the advice out there all although what is the deal with the airboot and how do you mod it
eric gore 265 kits
« Reply #13 on: January 16, 2013, 07:10:42 AM »
What's polishing the exhaust duct going to do?
eric gore 265 kits
« Reply #14 on: January 16, 2013, 07:22:31 AM »
The manifold does not match up with the carb very well and causes unwanted turbulance.
Get a die grinder and machine out the manifold to match the carb.
Result is better airflow.
Sorry, I meant manifold not airboot.
