Author Topic: Base Gasket Sealant  (Read 6713 times)
Offline 2005yz250
Base Gasket Sealant
« on: November 25, 2012, 03:17:37 AM »
Most kids my age want fancy clothes or money for Christmas.  I however have reason to believe santa is bringing me a top end rebuild kit from Weisco in the near future.  The bike is a 2005 yz250(as if my name didn?t give it away). I am getting a slight spooge escaping on the clutch side of the base gasket.  I was curious what type of sealant to use when I button everything back up to avoid future leaks.  Any help is greatly appreciated.  Keep on smokin' everyone. Braaaaaaap.
Base Gasket Sealant
« Reply #1 on: November 25, 2012, 04:49:01 AM »
None, you shouldn't need any sealant on your base gasket. Just a new gasket every time you take the barrel off.
Base Gasket Sealant
« Reply #2 on: November 25, 2012, 09:06:52 AM »
the only thing you should be putting on your base gasket is either 1) nothing if you want to listen to the maintenence manual or 2) a suitable oil or grease if your smart and dont want to spend a half hour cleaning old gaskets off the metal surfaces each time you rebuild you engine.
in the case of your bike using a metal base gasket you would go with option 1
