Author Topic: carb rebuild kit?  (Read 6017 times)
carb rebuild kit?
« on: February 22, 2012, 02:12:25 AM »
i need to rebuild the carb on my 1995 rm125 but i can only get the 1993 rebuild kit.... would this work? is it the same?
thanks
carb rebuild kit?
« Reply #1 on: February 22, 2012, 02:23:37 AM »
I'm not sure if it would work, but if you look up the carb diagrams online for the two years and compare them, then you should be able to see if it would.
carb rebuild kit?
« Reply #2 on: February 22, 2012, 03:49:16 PM »
The only thing that is really prone to wear in your carb is the needle and seat assy. and that should be readily available.
carb rebuild kit?
« Reply #3 on: February 27, 2012, 04:36:56 PM »
What are you trying to rebuild?  I'd contact (call) a carb parts supplier, example carb parts warehouse http://www.carbparts.com/ and ask then if they had what your looking for.
