Author Topic: 08 YZ250 steering head  (Read 8147 times)
Offline msambuco
« on: October 18, 2010, 11:27:51 AM »
Anyone know how to remove the lower steering bearing from the stem? The one on top comes right off but the lower one seems to be a tight fit or pressed on. Both need replacing so I need to get it off. Thanks.
08 373 Fuzion Toyhauler
1 wife, 2 kids, 1 dog
A lot of toys
A map and a credit card
Re: 08 YZ250 steering head
« Reply #1 on: October 18, 2010, 12:48:25 PM »
Yes, they are pressed on.
 My local shop charges $15 for the removal of the old bearing and pressing on a new one that I supply.
« Reply #2 on: October 18, 2010, 01:13:47 PM »
There are some do-it-yourself ways but unless you are handy with hand and power tools I am hesitant to explain lol. i don't want to be responisble for your ruining your steering stem due to my advice  :D
Safest bet is listen to PPMS's advice. My local shops SUCK so I do all my own work, but if you have a shop you like/trust definitely give them the job.
Offline snowboarderro
« Reply #3 on: October 18, 2010, 01:49:05 PM »
i do it myself,
but i dont know how to explain in enlish,
so sry
« Reply #4 on: October 18, 2010, 03:39:57 PM »
Remove your lower tapered (Timken) steering head bearing by first breaking the roller bearing cage and removing all the individual rollers. Then turn the lower triple clamp/stem upside down, heat the inner bearing race with a torch and it should fall off. Sometimes I've had to carefully grind through a stubborn inner race to remove it.
« Reply #5 on: October 18, 2010, 04:42:14 PM »
Or you can run a arc/mig weld around the bearing surface of the outer race which will shrink it and it will fall out.
Dont try this if you dont know how.
« Last Edit: October 18, 2010, 04:45:29 PM by TMKIWI »
