Author Topic: TPI  (Read 52511 times)
Re: TPI
« Reply #15 on: July 16, 2019, 07:42:58 AM »
Flettner has anyone ever called you a mad scientist...   ;D
Offline Flettner
Re: TPI
« Reply #16 on: July 16, 2019, 11:40:53 PM »
I've been called worse ;D
« Last Edit: July 16, 2019, 11:42:50 PM by Flettner »
Offline Flettner
Re: TPI
« Reply #17 on: August 27, 2019, 09:03:21 PM »
All the gears shown earlier are inside the this case. Bob weight and kick start gear / spring etc. Its all ended up a bit wider than I expected but too bad just needs to run now. This is the 360 with mk2 injection. Although this case look bulky it all machined from blocks of 6061, thin, so it all weighs bugger all.
Kick start is machined from a piece of 7075 block. Worked out nice in the end.
Offline Flettner
Re: TPI
« Reply #18 on: August 30, 2019, 12:47:56 AM »
See that nice 7075 kick start. First kick and it split in half. Bugger, O well ill build another in steel. 4140, and get it nitrided. In steel I can make it thinner.
