Author Topic: Pro-circuit pipes?  (Read 18242 times)
Offline dean.lilley
Pro-circuit pipes?
« on: April 02, 2014, 04:27:48 PM »
Hello im rebuilding a 92cr250 and was wondering if anyone knows the difference between the WORKS 95 pt number 0446 and the 92 PLATINUM pt number ph92250p?
I just bought the 92 as the 95 is getting rough
Pro-circuit pipes?
« Reply #1 on: April 02, 2014, 04:42:43 PM »
Hey dean, the pc pipes are  all the same power wise only the Finnish is different.
Offline dean.lilley
Pro-circuit pipes?
« Reply #2 on: April 02, 2014, 04:58:07 PM »
Just wondered jetting wise really i got the pwk carb on her and she doesnt run too well with 195 main jet it just drowns in goo, ive gone down to 165 to try this weekend with the new 92 pipe ??
Pro-circuit pipes?
« Reply #3 on: April 02, 2014, 07:19:01 PM »
Can't help you there brother.
Pro-circuit pipes?
« Reply #4 on: April 05, 2014, 03:50:46 PM »
Wow! no wonder.  Where did you come up with a 195 main?
Here is a good baseline jetting start using the PWK.  Tweak it from here for your temps and
altitudes: 168 main, 55 pilot, 1370M needle with clip on 3nd and the airscrew 1 1/2 turns out.
Offline dean.lilley
Pro-circuit pipes?
« Reply #5 on: April 05, 2014, 05:58:34 PM »
The 195 main came with the pwk carb from a hm honda cre250? I put it back to 165 for the minute, just wondering if the 16oz flywheel dc set up would make any difference?
Offline dean.lilley
Pro-circuit pipes?
« Reply #6 on: April 05, 2014, 07:15:29 PM »
Sorry ive got the 168 main in now, the slide is a 1360? And pilot 55 third groove needle thanks dogger
Offline dean.lilley
Pro-circuit pipes?
« Reply #7 on: April 05, 2014, 08:13:02 PM »
<iframe width="480" height="360" src="http://s101.photobucket.com/user/Dean_Lilley/embed/slideshow/"></iframe>
Pro-circuit pipes?
« Reply #8 on: April 06, 2014, 06:08:36 PM »
I'm hoping that number is a 1369, if so, you should be good to go for a baseline.
If it really is a 1360, you'll need to swap it out.  The needle will affect performance
from 1/4 throttle all the way to where the main jet takes over.
From the pictures, looks like a nice ride.
Offline dean.lilley
Pro-circuit pipes?
« Reply #9 on: April 06, 2014, 06:35:49 PM »
Still wondering Dogger where to drill the holes in the crankcase to ease oil flow to the clutch?
Many thanks Dogger i know youre a man of much knowledge!
Offline dean.lilley
Pro-circuit pipes?
« Reply #10 on: April 08, 2014, 04:35:26 PM »
Pro-circuit pipes?
« Reply #11 on: April 13, 2014, 05:57:35 PM »
I just sent someone some pictures on that on another site.  If that wasn't you, let me
know and I'll send them to you as well.
Offline dean.lilley
Pro-circuit pipes?
« Reply #12 on: April 18, 2014, 01:40:21 PM »
Dont think it was me unless i posted a while ago..cant remember...many thanks again dogger.
Pro-circuit pipes?
« Reply #13 on: April 18, 2014, 08:45:11 PM »
There you have it, straight from the Dog's mouth!
Sorry couldn't help myself  ;D
