Author Topic: engine knocking???  (Read 24495 times)
engine knocking???
« on: July 06, 2013, 07:05:51 AM »
http://www.youtube.com/watch?v=fv7eHbjiJrw&feature=youtu.be
is that a normal noise? it happened on my YZ250 and my CR125 before this.
engine knocking???
« Reply #1 on: July 06, 2013, 07:25:25 AM »
Does it always do it or some times?
engine knocking???
« Reply #2 on: July 06, 2013, 07:26:26 AM »
And does it go away when you rev it?
engine knocking???
« Reply #3 on: July 06, 2013, 07:33:28 AM »
Always does it but yes goes away when you rev it. Atleast I think it does. it might just be going to fast to hear it. Bigger pilot needed?
engine knocking???
« Reply #4 on: July 06, 2013, 07:49:10 AM »
Nah, that's just a ktm noise
engine knocking???
« Reply #5 on: July 06, 2013, 07:51:38 AM »
Ha.
What color is the plug?
engine knocking???
« Reply #6 on: July 06, 2013, 08:30:33 AM »
Thats what a 2 stroke sounds like Stu. ;D
Nothing to worry about. You should hear a KX250 idle  :o, sounds terrible.
Offline vetman
engine knocking???
« Reply #7 on: July 06, 2013, 09:58:52 AM »
could be your clutch plates vibrating in the basket they can rattle pretty hard depending on the model
engine knocking???
« Reply #8 on: July 06, 2013, 11:02:55 AM »
I thought so. Like I said both my YZ250 and CR125 made a similar noise.
Ha.
White shes running lean. I already knew this I just wasn't sure if it was a lean noise or a normal one.
Thanks guys.
engine knocking???
« Reply #9 on: July 06, 2013, 11:06:09 AM »
Ah well, drop the clip then  ;D
engine knocking???
« Reply #10 on: July 06, 2013, 05:14:28 PM »
Ya broke it already? Jeez stu  ;D Isn't that under warranty? Ride the p!ss out of it and if it breaks use the warranty if its got one. If not, ride it hard anyways, its a new bike
engine knocking???
« Reply #11 on: July 06, 2013, 11:04:50 PM »
KTM's don't come with a warranty....'cause they don't break..
Offline nom de guerre
engine knocking???
« Reply #12 on: July 07, 2013, 12:57:54 AM »
mine do the same.
engine knocking???
« Reply #13 on: July 07, 2013, 01:35:01 AM »
Huh... I wouldn't want a new bike with out a warranty. What if it had a proven factory defect, could you get it replaced or be SOL?
engine knocking???
« Reply #14 on: July 07, 2013, 08:08:31 AM »
They have, or atleast mine did, a selective warranty which basically means an ultra limited warranty. Obviously pistons/rings, oils, air filters etc etc etc aren't covered on a motocross bike but crankcase failure, crank failure within some small amount of time, and most other limited wear parts are covered according to my warranty booklet.
