Author Topic: 2002 yz250 running problems, higher gears  (Read 14826 times)
Offline yzkxf250
« on: June 26, 2013, 03:31:36 AM »
hello everyone.
I have just joined this forum for the purpose of trying to solve my yz250 issue.
Ok so i have a 2002 yz250 that suddenly lost power one day, it was running great then all of a sudden the engine refused to have any power in the higher gears, the bike runs great in 1st 2nd and then when im at high revs in 3rd it bogs down quite alot, it still accelerates but just not as it normally should, nor does it sound good at all,
1.The engine has a fresh top end, piston and rings, less than 1 hour on it.
2.fresh set of reeds less than 15mins on them
3.rebuild kit in carb including new float,
4.i believe its a 175 jet and on the 2nd clip for needle.
5.power valve was cleaned, i believe this is working fine.
6.carb has been cleaned many of times.
i have also noticed a grey oil that seems to gather round the carb, which is visable when the carb is removed.
could the crank seals have gone?
could it be the tpi?
I am pretty new to 2 stroke so any help from you guys would be appreciated
« Reply #1 on: June 26, 2013, 07:57:06 AM »
What colour is the plug.?
Check your trans fluid.
« Reply #2 on: June 27, 2013, 08:42:04 AM »
Grey oil around the carb is a new one for me. Like KIWI said post a picture of your plug thats the best place to start. When you say it doesnt accelerate normally do you mean a bog? Does the motor burble and sputter?
« Reply #3 on: June 27, 2013, 01:17:14 PM »
PV stopped working ?
Offline yzkxf250
« Reply #4 on: June 27, 2013, 07:47:24 PM »
Im jet to drain the tranny fluid.
The plug is a nice tan colour.  It starts great runs nice on stand etc. Idles fine to.
The power valve got a good clean but it definitely doesnt run at all in the power band. That is where the bogging comes from.
« Reply #5 on: June 27, 2013, 11:07:00 PM »
« Reply #6 on: July 01, 2013, 07:53:24 AM »
In that case its more than likely a powervalve issue. Pull it apart and make sure everything is in good nick.
« Reply #7 on: July 01, 2013, 12:59:00 PM »
If you recently did the top end, check the PV connector.  It sounds as though the PV is not working.
Offline rlaj1004
« Reply #8 on: July 23, 2013, 12:42:47 PM »
My son just did this to his 250SX.
It ran fine, low, idled great
When he did the top end, he clocked the PV incorrectly. Everthing looked right, ran right but no power as it revved. He has a shop manual and looked at a friends bike to compare but once he saw the problem it was, No ****. I think he had it 180 out??
I remember reading something about making sure the piston is TDC when you hook it up, but don't hold me to that. I will try and find it.
« Reply #9 on: March 04, 2013, 04:30:38 PM »
Definitely check the power valve. The same exact thing happen to me, it was fine for half the ride and then it literraly just stopped working. Had NO high end power. Took the assembly apart and found out the bolt backed out a little on the arm that pushes the valve which stopped it from opening the PV for higher revs.
« Reply #10 on: March 04, 2013, 08:43:14 PM »
I think he abandoned us  :(
« Reply #11 on: March 04, 2013, 09:03:30 PM »
im going to miss that guy.
« Reply #12 on: March 04, 2013, 10:11:58 PM »
he was a gentleman of fortune he was!
