Author Topic: YZ125 barrell  (Read 8464 times)
Offline thorns
YZ125 barrell
« on: May 13, 2013, 12:17:06 AM »
Has anyone bought a new barrel for a 08 YZ125 before, or can they be repaired?
Found a bike with a stuffed motor going for cheap and in the owners words it needs the following:
"Needs new barrel and piston as on last ride the ring broke and then scored the bore"
Any idea what a new barrel costs, or a ball park figure to get this up and running assuming the bottom end is all good?
Probably hard to tell, but figured some of you gurus might have a better idea than me.
YZ125 barrell
« Reply #1 on: May 13, 2013, 12:39:46 AM »
You shouldn't need a whole new barrel unless something went right through it. Worse case scenario you can have it re-sleeved for around $200 I think. With that, a top end kit for that bike should be about $120 ish depending on who you go with. That will come with new piston, rings, wrist pin, and all the gaskets. To do a quick check of the bottom end condition, try to wiggle the fly wheel. Any movement = blown bottom end bearings.
YZ125 barrell
« Reply #2 on: May 13, 2013, 07:59:46 AM »
As above. If it is only scored you just need to get it re Nikalsiled.
YZ125 barrell
« Reply #3 on: May 13, 2013, 03:40:34 PM »
Doesn't Athena make a top end for this bike?
Offline br8es
YZ125 barrell
« Reply #4 on: May 14, 2013, 05:28:06 PM »
Athena has kits, as well as a 134cc kit.
