Author Topic: My next project  (Read 169493 times)
My next project
« Reply #15 on: April 12, 2013, 01:38:16 AM »
Gotcha. Will do. There are only two thing I've never messed with on a bike, case splitting, and shock rebuilding.
My next project
« Reply #16 on: April 12, 2013, 01:54:27 PM »
From the looks of that piston it looks like one of the rod bearings fragged. I am really surprised the cylinder doesn't need repaired/replated. I am pretty sure those were plated. Try sticking a magnet to the bore. No stick, plated. Unless someone had it sleeved it previously a 1995 should be plated. I had a 1992 RM125 and it was plated.
My next project
« Reply #17 on: April 12, 2013, 05:21:01 PM »
Yeah the big end blew. The magnet sticks to the cylinder walls, kind of weakly, but it sticks. So I guess that means steal sleeve?  :-  If that's the case I will be honing out the shallow grooves that you should be able to see in these picks:
Also, the PV is all dented, I will be grinding the burrs out and hoping for the best.
My next project
« Reply #18 on: April 12, 2013, 07:49:33 PM »
Looks like a sleeve, take a pic from the bottom.
My next project
« Reply #19 on: April 12, 2013, 07:56:02 PM »
From the bottom:
My next project
« Reply #20 on: April 12, 2013, 10:13:58 PM »
Don't hone it, take it out to the next oversize.
My next project
« Reply #21 on: April 12, 2013, 10:39:15 PM »
Its sleeved. As kiwi says, bore that sucker.
My next project
« Reply #22 on: April 12, 2013, 10:46:41 PM »
Alright, I'll see what I can get my hands on. I'll be buying the big end bearing and splitting the cases as soon as I get the damn SA pivot bolt out.
My next project
« Reply #23 on: April 12, 2013, 11:20:10 PM »
Agreed, the pictures were very helpful. The thickness of the sleeve and if it was bored already will determine how far you can if you want to go bigger. Can you see any markings on the top of the piston or is it in too bad of shape to see?
My next project
« Reply #24 on: April 14, 2013, 03:21:42 PM »
The whole top of the piston is melted, I don't think I'll be getting any info from that sucker hahaha. I've been moving for the past few days and going now I'm going on vacation for a few days. I haven't had time to pound that SA bolt out, but I've been soaking in WD40, so hopefully it'll come out as soon as I get home.
My next project
« Reply #25 on: April 16, 2013, 02:10:44 AM »
Are you sure its a sleeve? Some suzuki people think its plated. If it was plated it wouldn't stick at all right? Like no connection at all? I can bore it for free but not plate it...
My next project
« Reply #26 on: April 16, 2013, 02:45:34 AM »
It could be plated but the pics(Blurry) are kind of hard to tell. I wouldn't be shocked if it were sleeved, you can get a steel sleeve for practically any bike.
After checking a few threads on other forums I guess sometimes other alloys make into the nikasil and a magnets will sometimes slightly stick(1/8 pull or less.) Scrub the top of the piston, you might get lucky. Again sorry for any missinfo (If any), pics can be deceiving.
My next project
« Reply #27 on: April 16, 2013, 03:23:44 AM »
It's all good man, things are hard to determine over pics hahaha. If it has a steel sleeve, but is in fact plated on the sleeve, can I bore it, which would get the plating off, and match a piston and run it with the steel?
My next project
« Reply #28 on: April 16, 2013, 09:43:39 AM »
This is gonna be sweet once its done. I can't offer advice as far as engines go, but I'm reading it anyway to learn :D
My next project
« Reply #29 on: April 21, 2013, 07:42:12 PM »
My patience is running very low with the bolt. It's the ONE thing holding me up from the rest of the project. I literally pounded on it for 10 minutes today with a 3 lb hammer and then upgraded to a 10 lb sledge with no luck. It wont press out. What do I do now? Can I cut it? If so, where with out damaging the frame and swing arm?
