Author Topic: 2005 cr250 clutch  (Read 7893 times)
Offline luthier269
2005 cr250 clutch
« on: January 11, 2013, 10:03:07 PM »
Just put in a new clutch. It is a little noisier when in nuetral with the clutch out. If you pull the clutch in it is quieter. Don't remember this happening with the old clutch.
2005 cr250 clutch
« Reply #1 on: January 12, 2013, 03:35:15 PM »
Did you replace aluminum plates with steel plates?
Offline msambuco
2005 cr250 clutch
« Reply #2 on: January 12, 2013, 07:48:37 PM »
Got your email. I am in DC right now. Be back later this week. Do you need help finding out what the noise is? X2 on steel plates like the above post. I rode my new 125 for one weekend last week and the aluminum plates are done already. Steel ones on order. That wouldn't be a noise source though. Did you do plates only or a whole clutch?
08 373 Fuzion Toyhauler
1 wife, 2 kids, 1 dog
A lot of toys
A map and a credit card
Offline dbf498
2005 cr250 clutch
« Reply #3 on: January 12, 2013, 10:15:34 PM »
When you replaced your clutch did you replace the center bearing and collar on the clutch basket? If there is too much clearance between the bearing, collar and basket it will make noise with the clutch in neutral but will go away when you pull the clutch in; this is a common problem with Honda CR250's.
 Items 5 and 23 are what I've had to replace to cure the noise problem on my '01 CR250.
Offline luthier269
2005 cr250 clutch
« Reply #4 on: January 12, 2013, 11:16:37 PM »
I replaced both steel and fiber plates. Did not replace the bearings tho.
Offline luthier269
2005 cr250 clutch
« Reply #5 on: January 12, 2013, 11:39:11 PM »
I had Surf and Turf Racing in Connecticut Mill my basket and inner clutch hub like a hinson they charge $50
