Author Topic: Time for a new VINTAGE TOPIC....What do you ride in 2013 ????  (Read 15052 times)
Offline Helmut Clasen
  • Helmut Clasen
    • 50 years of 2 wheel sporting
« on: December 17, 2012, 05:46:28 PM »
 :D,...in a short time the Toronto MC show (International center,the REAL one) goes on.
I will be there with my 2013 weapons.
My body Gary Richards will be with me with 2 of his Zuendap weapons.
Cant wait.
Here a little PRE-SHOW.....
3xSACHS MC-GS 250 1977
1xHercules GS 250  1976
1xHercules GS 350  1976
1xCan-Am 175 TNT 1975
1xZuendapp GS 125 19072-73
http://speedy_c.tripod.com
http://picasaweb.google.com/vindurospeedy
« Reply #1 on: December 17, 2012, 08:40:54 PM »
I'll be back doing more of this
And if I can convince them to run a vintage class for the 6 hour, maybe I'll run this and we can battle it out  :P
« Reply #2 on: December 17, 2012, 09:30:59 PM »
cool video, i saw a young kris kringle at 3:10.
« Reply #3 on: December 17, 2012, 10:57:48 PM »
Hopefully I can find something old and cheap on craigslist in a few months so I can do MX rewind at unadilla.
« Reply #4 on: December 18, 2012, 12:17:03 AM »
That was Ford at 3:10.
 As I'm too beat up to race anything current in 2013 I'm building two vintage/evo  bikes for fun/vintage events:
1. 1975 Hercules Sachs 1751 6A with a 1975 Maico fork assy. and rear shocks to match (hopefully Ohlins - not period correct but for fun).
and
2.  1979 Hercules Sachs 175 7 sp with a GS 6/MX 250 style frame with 300 mm of travel (another one off special).
Should be fun. ;D
« Reply #5 on: December 18, 2012, 06:15:27 AM »
Will be doing more of this on the 125.
And am trying to do a deal on a 250 at the moment so I can do 2 classes at each event.
I wouldn't mind a 500 to complete the collection as well. 8)
« Reply #6 on: December 18, 2012, 06:30:12 AM »
Here you go msmola
http://reno.craigslist.org/mcy/3461990469.html
http://reno.craigslist.org/mcy/3451678079.html
There's even more than this around here   :D
« Reply #7 on: December 18, 2012, 03:28:46 PM »
WOW that AJS looks fantastic! Wonder what a Mukuni carb is?   ;D
Here you go msmola
« Reply #8 on: December 18, 2012, 03:32:28 PM »
I ride a '73 yamaha CT3 175.
And recently my daughter started riding a full sized bike for the first time.
And of course its another two stroke -- 1986 IT200. This was a parts donor
bike for the prior owner until we rescued it....
Offline Uniflow
« Reply #9 on: December 20, 2012, 03:18:48 AM »
Citabjockey, how's that RT3 going?
Offline Uniflow
« Reply #10 on: December 20, 2012, 04:28:19 AM »
« Reply #11 on: December 20, 2012, 05:41:35 AM »
The RT3 is working pretty well. There is a jetting (or possible small air leak) issue when it gets hot, at higher engine rpms and low throttle settings. There is a small range of throttle settings where it can ping. I really have to figure that one out sometime. Its pretty easy to avoid that operating mode so its been back burnered.
Offline Uniflow
« Reply #12 on: December 21, 2012, 07:14:45 AM »
citabjockey, sorry about the crappy video at least you can see the bighorn running. This is the first time started with the "ball valve" intake. tuning is all wrong now as the TPS to airflow is different. I need a bit of time to re tune it. You don't have an air leak around the reed rubber on your RT3? They do crack when they get old. Not trying to tell you how to "suck eggs" just it's something I've noticed with all my old Yamaha rubber boots.
« Reply #13 on: December 21, 2012, 09:29:13 PM »
Hey Uniflow, that bighorn project has me glued to your posts. I love this research project.
For the RT3, this is the older intake design where the reed block has studs in it to mount the carb solid to it with a 1/4" fiber spacer in between. This unit is not leaking. There is a small amount of oil accumulating around the exhaust side of the base gasket so I think that is probably the culprit. But -- have to setup a leakdown testing to be sure 1) that there is a leak and 2) that when I think its fixed it REALLY is fixed.
Offline Uniflow
« Reply #14 on: December 21, 2012, 11:43:02 PM »
Took the Bighorn for a quick lap round the back yard, if you hit second you are in the fence. Tight, but the Bighorn seems a lot cleaner around the bottom end where there was a problem earlier. Much nicer throttle response. I better give it a wash before the next video.
