Author Topic: Want to see something Badass?  (Read 8167 times)
« on: October 04, 2012, 01:23:34 AM »
RZ500/R6 hybrid
http://cgi.ebay.com/ebaymotors/Yamaha-Other-Custom-Built-RZ500-R6R-hybrid-The-One-Yahama-Should-Have-Built-Show-Quality-/251160107195?pt=US_motorcycles&hash=item3a7a4f18bb#ht_1705wt_1166
(Still bad ass despite it not being tuned correctly)
Engine
Fully rebuilt with new (OEM Yamaha) seals, gaskets, and bearings
.5mm Over Bore
New Wiseco Pistons, rings, pins
New Carbon Tech reeds
New Mikuni TM28 Flat Slide carbs
New K&N Air Filters
New ZeelTronics Programable CDI and Power Valve Controller
Stock Ports and heads
New Jim Lomas GP Style Expansion Chambers and Polished Silencers
Set up with functional Auto Lube
Frame
Modified 1984 RZ500 Frame
Custom built rear sub-frame
2009 R6R upper fairing bracket
2009 R6R Radiator
Oil tank under seat cowl and battery under upper fairing
PA TITLE!!
Suspension
2009 R6R Aluminum Swingarm
2009 R6R Upside Down Front End
RZ500 Rear Shock
2009 R6R Front and Rear Wheels
2009 R6R Radial Front and Rear Brakes
New gold X-oring chain and sprockets
Body
Stock RZ500 fuel tank modified with flush filler cap
2009 R6R front and upper fairing
209 R6R Tail section and seat
Koso digital instrument panel
Yamaha 50th Anniversary Graphics
Show quality PPG base and clearcoat paint - OEM 50th Anniversary "Reddish-Yellow Cocktail"
RD400/RZ350 Hybrid
http://cgi.ebay.com/ebaymotors/Yamaha-Other-Custom-Built-Hybrid-RZ350-RD400-TZ250-Street-Legal-2-Stroke-Show-Quality-Bike-/251159646259?pt=US_motorcycles&hash=item3a7a481033#ht_1605wt_1166
Engine
?Fully rebuilt with new seals, gaskets, and bearings
?1mm Overbore (426cc)
?New ProX Pistons, rings, pins
?New TDR reeds
?New 30mm D Slide carbs
?New MZB Electronic CDI ignition and charging system
?Stage 2 porting and combustion chamber mods by Vintage Porting
?Custom expansion chambers and mufflers
?Hydraulic clutch conversion with stainless steel line
?Set up for Pre-mix
Frame
?Modified 1984 RZ350 Frame
?Custom built rear sub-frame
?Frame designed to fit RD400 Air Cooled Engine
Suspension
?FZR600 Aluminum Swingarm
?GSXR600 Upside Down Front End
?R6R Rear Shock
?GSXR 600 Front and Rear Wheels
?GSXR 600 Front and Rear Brakes
?Stainless steel brake lines
?New gold X-oring chain and sprockets
Body
?Aluminum TZ250 fuel tank with NOS decals and hold down strap
?Hand laid-up 2003-2009 TZ250 front fairing designed to split down the middle for easy service
?2003-2009 TZ250P Tail and seat section
?Hand laid-up undertail with LED lighting
?Low/High beam headlamps molded into upper fairing
?Trailtech Vapor digital instrument pane
?Show quality PPG base and clearcoat paint
« Reply #1 on: October 04, 2012, 01:39:10 AM »
 :o 8)
« Reply #2 on: October 04, 2012, 07:53:33 AM »
 8)
I must get myself another RZ350.
« Reply #3 on: October 04, 2012, 12:25:18 PM »
Please Santa?   :o
Offline shanes
« Reply #4 on: October 09, 2012, 07:45:31 AM »
love it
« Reply #5 on: November 02, 2012, 10:36:08 PM »
That first video, goes slowly...slowly... Then takes off like a shower of sh**. You roadies are crazy good and generally crazy.
« Reply #6 on: November 03, 2012, 12:34:40 PM »
The bike isn't tuned right, the gearing is ultra long as well.
