Author Topic: Air Pressure  (Read 8357 times)
Offline DESERTFOX19
Air Pressure
« on: August 02, 2011, 09:58:30 PM »
What air pressure do you keep your front and rear tires at?
Re: Air Pressure
« Reply #1 on: August 02, 2011, 10:05:20 PM »
12-13 for rocks.
8-9 for mud
Re: Air Pressure
« Reply #2 on: August 03, 2011, 05:39:17 AM »
10-12 in the front
8-10 in the rear (trials tire)
I only ride off-road, no racing.
Offline dk
Re: Air Pressure
« Reply #3 on: August 03, 2011, 07:15:23 AM »
Rim Clean Method!!...google it.
http://youtu.be/uwfc6MYDSt0
I started doing this a year ago and wish i would have figured it out years ago.
Offline dk
Re: Air Pressure
« Reply #4 on: August 03, 2011, 07:37:23 AM »
10 to 9 psi in the front and 11 to 10 psi in the rear.
Rubber:  I run Dunlop mx51's (front/rear).
Type of Riding:  Motocross only at a novice level.
My Weight:  153lbs.
Bike:  2006 kx 250
Re: Air Pressure
« Reply #5 on: August 21, 2011, 06:53:43 AM »
What TMKIWI said is the setup but I typically run 12 psi(hot) for all conditions-and use heavy duty tubes.Even in the goo here,there are lots of rocks.
Re: Air Pressure
« Reply #6 on: August 21, 2011, 08:16:02 AM »
We usually run 11-12 PSI in Jeremys front and rear MX 51's.
