Author Topic: race sag static sag  (Read 19977 times)
Offline thepope
race sag static sag
« on: April 02, 2011, 01:25:10 PM »
Hello there! so i was looking at my 05 yz 250 and was about to check the race sag and stuff. and i came to a conclusion that i needed a stiffer spring. time goes by and i was pondering on the race sag and such.. and i said to my self.. -HEY! if my race sag was 115mm and my static sag was 36 .. then perhaps i dont need a stiffer spring?
 if i adjust the rear shock 10mm i would have 26 static sag and 105 race sag right?
Or am i way to tired to understand the simple maths, or unwilling to spend more money on my bike, so i have to find a cheaper solution to get my bike prepped and ready to go before  the season starts.
Sorry for bad english :)
Re: race sag static sag
« Reply #1 on: April 03, 2011, 04:46:25 AM »
You're likely not far off.Set your race sag to 100mm and recheck your static.If you're 25mm or thereabouts,you're good to go.
« Reply #2 on: April 03, 2011, 04:57:23 AM »
If I were to set my race sag to 100mm on my KX250 it would have so much head shake it would be impossible to ride.
Your race sag should be between 105 and 120mm, depending on the track conditions, the lower number for tighter stuff and the higher number for faster more open courses. Less race sag will steepen the rake on your steering making the bike turn faster, while more will lengthen the rake and make the bike more stable at speed.
And to answer your question, YES, you currently have too much preload on the spring. Loosen the lock ring, and take a few turns out until you get it to 105mm. Then re measure your Static it should be right on the money.
« Reply #3 on: April 04, 2011, 03:33:09 PM »
25mm(1 in) static sag and 100mm(4 in) race sag is where it should be.If you have to go less than about 95 or more than about 105 you should look at getting a different spring.
If you have to go 120mm mcclung you're chasing a geometry or other set up issue.Maybe you need a pro circuit link or drop the front end in the clamps.The pope has a YZ and 25/100 is good,and the accepted norm.However,that's a bike that's engineered and executed properly.The same can't be said for all the other manufacturers  :P ;)
Offline thepope
« Reply #4 on: April 05, 2011, 02:21:30 AM »
thanks for clearing that up :) oh yeah.. havnt been riding dirtbike since 2003 and that was a 1993 yamaha yz 125. it was abit slower than a 05 yz 250 :)
But how much should the top end at the clamps drop at a rough sandy track? i dont remember right but its over 15mm down i think..
« Reply #5 on: April 05, 2011, 09:45:28 AM »
Ha Ha, Duh Ford, it is an 07 KX250 ;),the forks ARE flush with the clamps. Pro Circuit doesn't have the link in stock, and they don't have any plans to produce more, I can't find anyone who does stock it. I had my suspension guru valve the shock knowing about the extra 10- 15mm of sag and the spring being 1 rate stiffer for my weight, it's real good now.
If you can find one even used, send me a link, I will sell a kidney if I have to.
« Last Edit: April 05, 2011, 09:49:46 AM by MyckMcClung »
« Reply #6 on: April 05, 2011, 01:57:44 PM »
Personally,once I have my suspension working well,I leave the fork position alone for everything.A little less compression front and rear for the woods but that's about the only deviation I make for conditions-sand,mud or hardpack.On the other hand,I hate sandtracks  :D
« Reply #7 on: April 05, 2011, 01:59:29 PM »
A YZ don't need no stinkin' aftermarket link to work properly  ;D ;)
I'll keep an eye out for you around here to see if one turns up.
Offline beckvall
« Reply #8 on: April 14, 2011, 03:51:40 AM »
if i may borow this thred for a question? i hawe a honda cr 125 tunder by srs. how mutch race sag should i have? and so on? greatfull for awnsers!
is from Sweden so excuse my bad English
honda 4 life!
Offline George
« Reply #9 on: April 14, 2011, 05:27:14 AM »
as a genral rule, all mx bikes should be around 25mm static sag and 100mm race sag when your sat on the bike. And for the guy running 120mm rear race sag, have you tried harder forks? maybe they are diving too much?
« Reply #10 on: April 14, 2011, 09:55:29 AM »
the problem with the 2003 up KX's, is solely due to frame geometry, Kawasaki took almost 2 degrees of rake from the head tube when they redesigned the KX line for 2003. This took away the formerly super stable feel the earlier KX models were famous for. The rear shocks also have a very fast rising rate that it not easily controllable at the rebound clickers with the stock valving. It adds to the stink bug feel and makes the rear end want to ride too high in the stroke.  So to compensate for the steep rake the back of the bike needs to be lowered to add rake to the front end. Pro Circuit accomplished this with a 3mm longer link. it lowers the rear end almost an inch feeding rake into the front end and changing the rising rate of the shock to a more acceptable speed. I accomplished this task simply by adding an extra 10 mm of sag. I must also add that the rear spring is .1 kg  heavier than ideal for my weight and I had the shock revalved for off road to accommidate the extra 10mm of sag. Works great.
Offline beckvall
« Reply #11 on: April 14, 2011, 11:11:25 PM »
if i got 28mm free sag and 90mm static sag do i need a softer spring then?
honda 4 life!
Offline George
« Reply #12 on: April 15, 2011, 01:24:50 AM »
Your about on the limit, you could try setting free sag at 25 and if you get 95 static then it should be good, but talk to a suspension guy if your unsure, but your not massivley out :)
Offline beckvall
« Reply #13 on: April 18, 2011, 12:07:48 AM »
then i need to compress the spring and then i wil gett around 80mm race sag? less free sag less racesag?
honda 4 life!
Offline George
« Reply #14 on: April 18, 2011, 02:25:04 AM »
Sorry, I meant to say set 30 ish and try and get 95, you should get a happy medium somewhere very close to perfect
