Author Topic: fork stiker isuee  (Read 11006 times)
Offline snowboarderro
fork stiker isuee
« on: October 30, 2010, 07:50:30 AM »
so i pulled of the stikers from the fork
the problem is that some kind of plastic remaind on the fork
how do you take it off
i tryed with gasoline and and paint solvant....
Re: fork stiker isuee
« Reply #1 on: October 30, 2010, 10:15:22 AM »
spray it down with wd-40, let it soak for a few minutes, rub it with a rag, repeat until clean.
« Reply #2 on: October 30, 2010, 11:12:45 AM »
10x i will give it a shot
« Reply #3 on: October 31, 2010, 04:36:17 AM »
There is a product out there called "sticker off"(and sticker on too)that is supposed to do a fine job but I've never used it.
I usually get what I can carefully with a razor blade then do what Glenn says.
« Reply #4 on: January 15, 2011, 07:07:04 PM »
brakekleen
« Reply #5 on: January 15, 2011, 07:13:17 PM »
Brake clean, rubbing alcohol, gasoline, etc..
« Reply #6 on: January 16, 2011, 05:48:30 AM »
I don't recommend this because it's easy to mess up your bike, but I use a heat gun when removing stickers. Once they get hot where you can barely touch them, they pull right off and leave very little glue behind. It only takes a couple seconds. But like I said, it's tricky and you can mess up your stuff so I would try what the others mentioned, some chemical to remove the glue residue.  :)
« Reply #7 on: January 16, 2011, 08:37:54 AM »
coop i know the heating part but the stiker was allready starting to fall off and the glue still on
« Reply #8 on: January 16, 2011, 09:09:28 AM »
Acetone works well.
« Reply #9 on: January 17, 2011, 04:05:33 PM »
I use a hair dryer when applying and unapplying graphics, the heat gun is a little overkill even on the low setting. But works wonders at getting out those white stress marks the blue yamaha plastics get.
« Reply #10 on: January 17, 2011, 04:06:03 PM »
Nail polish remever works well too, it's acetone
