Author Topic: Can you name the bike??  (Read 73885 times)
Offline Helmut Clasen
  • Helmut Clasen
    • 50 years of 2 wheel sporting
Re: Can you name the bike??
« Reply #45 on: March 03, 2010, 07:48:10 AM »
Hello Helmut,
I'm almost 1.93 metres in height (6-5).The reason that I pursuaded Horst to give me the Ceriani's is that the forks had 13mm more travel then the Zoke's and far superior action.These Ceriani's were special forks that he had on a Sachs MC250 and the travel exceeded that of the stock Marzocchis. On a different subject,where did you get that reed cylinder?
Somebody on the German Offroad forum offered the cylinder.I talked to him and we made a deal.What came was a reed cylinder where somebody with the wrong tools pulled the liner out and made the inner diameter oval plus they cracked one fin.(the bugger never told me that.) ::)
I send the cylinder and a new 250 Piston to a company in Quebec,asking them to,fabrikate a new sleeve,port it and fit to the piston and mentioned my dream would be Nicasil.
They called me and said,no Nicasil on top of a SLEEVE,but they had to weld the inner bore anyway to get it round,so why not adding some more layers of alu welding,bore it,port it and Nicasil it to fit.
I was in heaven,they did,(they welded the cracket fin over beautyfully) and I have a REED-NICASIL Cylinder.Works like a charme. :D
3xSACHS MC-GS 250 1977
1xHercules GS 250  1976
1xHercules GS 350  1976
1xCan-Am 175 TNT 1975
1xZuendapp GS 125 19072-73
http://speedy_c.tripod.com
http://picasaweb.google.com/vindurospeedy
« Reply #46 on: March 03, 2010, 08:39:48 AM »
Hello Helmut,
 That reed cylinder,was it stock Sachs or something special that someone fabricated?If it was stock,what model of Sachs/Hercules would have used it? Thanks.
  • Helmut Clasen
« Reply #47 on: March 03, 2010, 10:09:45 AM »
Hello Helmut,
I understand that Sachs for its 250 MC -5  fabricated a few reed cylinders using Honda reeds,shortly before they closed the off road division.
This cylinder is a original Sachs cylinder,not changed over from a standard one.
