Author Topic: KX250 front brake problem  (Read 18445 times)
Offline jamez-0001
« on: October 26, 2013, 08:29:28 PM »
Hi,
Got a bit of a bizarre problem - maybe someone can help?
KX250 1997 with nissin twin piston brake caliper and master cylinder. Front brake very weak. When pushing the bike and applying brake, it won't stop completely. Have bled system and lever feels quite firm and doesn't loose firmness when held down. Pistons are moving freely. Pad guide pin is a bit grooved. Have cleaned brake disc thoroughly and put a set of new pads in. All to no avail. The really odd thing is that after washing the bike down with water, the brake grabs much better! Can't get my head round it  :<img src=" title="Roll Eyes" class="smiley">
« Reply #1 on: October 26, 2013, 11:07:14 PM »
Something on the pads?
« Reply #2 on: October 26, 2013, 11:57:20 PM »
x2 go somewhere you can ride in a straight line, ride along in first gear and drag the brakes until it gets quite hot. Hopefully that will evaporate whatever is on them. Sometimes if you spray WD-40 on the bike somewhere, it can mist over and settle on the rotors or something like that. I find degreaser is just as bad so if you were washing your axles with that be careful.
« Reply #3 on: October 27, 2013, 01:44:26 PM »
I agree...  (I can't believe I'm tying this :-[ ) Try Stu's method and let us know what happens...
« Reply #4 on: October 27, 2013, 02:51:01 PM »
The brake caliper is typically mounted on pins which allow it to "float" and position itself on the disc. Make sure it's not seized. As well, make sure the disc itself is not warped or heavily glazed.
« Reply #5 on: October 28, 2013, 12:31:03 AM »
Happy day! Don't do it often though unless you really like replacing brake pads ;D
« Reply #6 on: October 28, 2013, 05:14:13 AM »
Most new pads need to be "broken in", this process is usually written on the manufacturer packaging somewhere (that we never read) which could help.
« Reply #7 on: October 28, 2013, 05:22:42 AM »
Good thought. Fresh rotors need a little break in too I'm told. Running a KTM means you never have to buy another one  ;)
Offline jamez-0001
« Reply #8 on: October 30, 2013, 09:27:53 PM »
Cheers for the tips guys; I'll try these suggestions on Saturday!
Offline jamez-0001
« Reply #9 on: November 08, 2013, 06:49:10 PM »
Got brakes working a lot better! I followed the suggestions and rode the bike slowly with the front brake on. Seems to have done the trick! I think the disc was glazed over, as the old pads didn't bite either. I remember cleaning disc with electro contact cleaner at some point, which maybe didn't help. Seems to have worked a treat - cheers guys, much appreciated!
« Reply #10 on: November 10, 2013, 12:36:04 AM »
not a worry mate glad its sorted. Just don't do it often cos it eats pads.
