Author Topic: Newbie few minor problems on new YZ 250 '04.  (Read 13803 times)
Offline falk_ben
« on: October 29, 2012, 02:46:54 AM »
Hi Guys,
New to 2 strokes so I thought I'd join for a bit of guidance!
Just bought a YZ 250 '04 plate. Loved my mates CR 250 '07 so the 2 Stroke bug clawed back childhood memories(twos up hitting powerband through fields on older teens bikes wearing t-shirts but no helmet). Owned a CRF 450 R for 18 months before my YZ but I don't miss it!
Just checked over my latest shipment to the Falkland Islands and it's not a bad bike but requires abit of attension!
Starts and runs OK, quite surprised at the gearing being 14/46( a little tall). It's got a lot more go than my CRF!
My concerns are low water in rads, trans oil milky grey, and the shraider valve has snapped off my shock! I guess my water pump seal has failed? Can I get the valve? looks like they are replaceable. Does it get filled with air or nitrogen?
I wonder if my suspension is standard too? There are stickers with Pro Action 3 stage incremental! Does this mean they have been re-valved?
Great stuff on here
Ben. :)
Newbie few minor problems on new YZ 250 ''04.
« Reply #1 on: October 29, 2012, 11:38:46 AM »
Sounds like the seal failed, the valve can be replaced, and nitrogen for the refill.
Offline arnego2
Newbie few minor problems on new YZ 250 ''''04.
« Reply #2 on: October 29, 2012, 11:46:54 AM »
Sound like you need a new water seal of the water pump shaft. Maybe also the shaft. Did you look up the piston? When buying a used bike that is the first thing I could do. The shock you could repair it with a new shredder valve. It happened to me and I used a car tire valve. So far it is OK I think on the YZ250 you can change the valve anyway. The shock uses nitrogen 140psi is stock, I use 150psi.
It is quite easy to do all the work yourself. Top end, Water pump shaft seal ( maybe also the shaft) plus the shredder valve you looking at about 4 to 6 hours.
Offline falk_ben
Newbie few minor problems on new YZ 250 ''''''''04.
« Reply #3 on: October 31, 2012, 02:14:43 AM »
Thanks alot for the help.
I can remember changing the waterpump shaft on my crf, so i guess it's the same.
Why did you charge 150psi instead of 140psi?
Are my Pro Action suspension standard? I thought they would be KYB. If so would fork seal part numbers be different?
Can't wait to ride this beast  ;D!
Offline arnego2
Newbie few minor problems on new YZ 250 ''''''''''''''''04.
« Reply #4 on: October 31, 2012, 11:39:15 AM »
I read about benefits of the higher charge, hard to tell if they are true, before I had hardly 70psi in there.
As for you suspension I'd give the company a call.
Pro Action have probably just revalved the suspension.
Your seals should be the same.
