Author Topic: EFI Bighorn  (Read 104606 times)
Offline Uniflow
EFI Bighorn
« Reply #45 on: December 12, 2012, 01:05:21 AM »
Here are some cores for a uniflow twostroke engine cast here. First core is CO2 hardening sand, exhaust cylinder,second core is shell hot set sand ( yellow ), transfer port.
EFI Bighorn
« Reply #46 on: December 12, 2012, 02:59:11 AM »
Fascinating. If you've got the time I'd be interested in a quick visual explanation of what you do from conceptual drawings to finished project. ;D
Offline Uniflow
EFI Bighorn
« Reply #47 on: December 12, 2012, 05:30:07 AM »
If I get a chance this weekend, I'm making a cylindrical throttle body for another application ( YZ250 with EFI ). I'll be making a pattern and casting them as I might want a few. I'll take pictures and explain the process as I go. This will use a cold core box ( CO2 sand ), not a hot metal core box. I will cover that later.
Offline Uniflow
EFI Bighorn
« Reply #48 on: December 12, 2012, 08:19:41 AM »
Casting, pattern making and machining are my hobby and job. So if I get a little carried away just say so. To cast a twostroke cylinder first you need cores then a pattern. I make my cores often with a rubber mold of a cylinder I like the port shape of, then copy into a two pot casting resin. So you end up with ( male ) transfer port shapes like this.
Then these need to be copied back into a core box, so you can make more of them ( in casting resin for the cylinder pattern itself ) and ultimately these boxes will make the hard sand cores you cast with. Basically you manufacture the cores first ( in casting resin ) stick them all together, then add thickness on top of that.
This is the pattern being made up of the resin core prints. What is solid here will be holes in the casting ( when done in sand ).
This is the main cylinder and exhaust port as one core, here is the box it's made in.
Here is the pattern made with all the smaller cores glued inside. You can see the core prints ( tapered bits on the ends) sticking out. This gets invested into sand then removed. While the sand mold is apart, hard sand cores are fitted ( transfers / water gallery etc ) They will fit neatly into the core prints provided by the mold as it was invested. With the mold back together and cores in place, metal is poured in. Where there is sand ( as in a core ) there will be a hole ( port ).
Thought I had some pictures of the sand mold set up and pouring, but must have deleted them?
I have others but not of twostroke parts.
Offline Uniflow
EFI Bighorn
« Reply #49 on: December 12, 2012, 08:28:07 AM »
I find the best way to add uniform thickness to the transfer ports is to stick hundreds of 4mm plastic beads, bondi fill over then sand back until the edge of the bead appears. So you end up with a 4mm thick wall around the ports or less if you use smaller beads. Larger pieces are glued on where studs have to go.
Offline Uniflow
EFI Bighorn
« Reply #50 on: December 12, 2012, 08:34:00 AM »
These are the water cores, done in shell hot set sand, in a metal mold. Each half is glued together with a special sand glue, can handle the heat of casting.
Offline Uniflow
EFI Bighorn
« Reply #51 on: December 12, 2012, 08:36:07 AM »
Like I said, this is what I do when I want to relax, apart from riding twostrokes!
EFI Bighorn
« Reply #52 on: December 12, 2012, 01:47:02 PM »
What bore size and bolt spacing? Here is one to copy the ducts off. Let me know if you need the drawings.
EFI Bighorn
« Reply #53 on: December 12, 2012, 03:10:33 PM »
Thanks Uniflow! Do you do the actual casting (metal pouring) your self? And is there somebody in NZ who can do the nicasil plating?
Offline Uniflow
EFI Bighorn
« Reply #54 on: December 12, 2012, 07:32:15 PM »
Yes to nikasil, it's done in Ashburton. I did have a crucible but it got damaged when it was left out while hot still hot one night. There was a cold wind and one side cooled  while the other didn't, so it cracked. It was too hard to keep the temp constant, the alloy would be damaged if it got too hot and not respond to heat treating. It was a fairly rough affair. I get everything cast in Thames now, about 100 Km away by Thames Foundry Ltd. The owner is great as he lets me come in and do my own stuff. He just pours it for me. Here are some pictures of casting in the back yard a two cylinder fourstroke head to suit a Subaru EA82. I know this is getting off track a little, note the safety gear we use!
Fuel pump is by gravity and it's running on ethanol ( with a little castor ).
Offline Uniflow
EFI Bighorn
« Reply #55 on: December 12, 2012, 07:33:31 PM »
Finished product.
Offline Uniflow
EFI Bighorn
« Reply #56 on: December 12, 2012, 07:36:58 PM »
2T, what core is that out of ? Mine is 80mm bore with 10mm studs at 100 centers square.
EFI Bighorn
« Reply #57 on: December 12, 2012, 08:39:35 PM »
Aprilia GP 54mm bore.
EFI Bighorn
« Reply #58 on: December 12, 2012, 10:13:21 PM »
have you ever lost anything in a bizarre smelting accident. no really i don't care about too much technical stuff but this is pretty interesting.
EFI Bighorn
« Reply #59 on: December 12, 2012, 10:34:04 PM »
were you hoping we could call him Aluminium-Member? LOL
