Author Topic: Wiseco GP pistons?  (Read 8238 times)
Wiseco GP pistons?
« on: June 13, 2012, 02:55:10 PM »
I should do a piston and ring in my RM soon. I was looking for a deal on ebay, and saw the GP pistons.
http://www.ebay.ca/itm/320924696190?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Is there anything special about them? I usually use the standard pro lite.
Wiseco GP pistons?
« Reply #1 on: June 13, 2012, 03:45:43 PM »
Yes.  The GP series have a number of unique upgrades over the standard Wiseco.
First of all, the picture in the EBay ad is not a GP piston.  It's a standard Wiseco
Pro-Lite.  Changing to a GP piston gets you hard coat anodized, single ring Ti
Nitride coated ring, pinned on centerline and no intake window.
Wiseco GP pistons?
« Reply #2 on: June 13, 2012, 08:22:04 PM »
What's the significance of no intake window, and are they worth the extra money? I have heard that you can get longer service out of them.
Wiseco GP pistons?
« Reply #3 on: June 13, 2012, 09:36:39 PM »
Single ring pistons aren't known for long service life, they're all about lighter
weight, higher revs and more power.  The only feature that might provide
a longer life is the hard coating on the piston.
As for the missing window, I have no idea.  On the Honda version of this piston,
it's a close copy of what HRC used on the works bikes - single ring and all.  I
wouldn't be surprised if this is a close copy of what Team Suzuki used on their
bikes.
If you are looking for a replacement piston that features a long service life,
you're better off with a Pro-Lite.  It's a forging and will be nice and durable
under most conditions.
Wiseco GP pistons?
« Reply #4 on: June 13, 2012, 11:07:35 PM »
That's what I normally use. It is also a single rung. I thought I read on the Wiseco site that longer service life is possible.
Thanks.
Wiseco GP pistons?
« Reply #5 on: June 14, 2012, 05:03:43 AM »
That ebay pic is a 250 piston, all 125,s from about 1995 have 1 ring. The gp piston has a thicker dome also, very durable piston.
Wiseco GP pistons?
« Reply #6 on: June 16, 2012, 04:04:59 AM »
The pic is of a Banshee piston. The Wiseco is hardly 'GP" spec, a ring weighs 1-2 grams hardly world beating stuff. The coatings wear off pretty fast on a piston. Average mass of a 54mm piston is 125-130grams a proper GP spec 54mm piston weighs 109g.
Wiseco GP pistons?
« Reply #7 on: June 16, 2012, 12:33:41 PM »
fairly useless in a stock or midly tuned bike.
Wiseco GP pistons?
« Reply #8 on: June 16, 2012, 01:30:27 PM »
Why?
Wiseco GP pistons?
« Reply #9 on: June 16, 2012, 02:24:36 PM »
you wont get any extra hp with this piston
no extra hp at higher revs with this piston in a stock motor
the stock motor is already reliable with the stock piston that is heavier/twin ring.
what you gain in reliability with the lighter weight, you loose with the single ring.
only real advantage in my opinion is if you have a motor and pipe combo that makes big power and high revs. perhaps a super kart for instance.
but if you were running a 54mm piston in a high revving bike that needed the best of everything youd be silly not to just buy a GP piston such as an Aprilia RSA125 (54mm) piston (80 euros?) and then match in the height using a different connecting rod length and or spacer plates. Im sure its been done before by someone.
Wiseco GP pistons?
« Reply #10 on: June 16, 2012, 04:14:09 PM »
Stock is single ring. The GP is supposed to offer longer service life, as I have found out since I originally posted.
Wiseco GP pistons?
« Reply #11 on: June 16, 2012, 04:49:05 PM »
Yeah Beaner the Rm  is a single ring, along with yz, and cr,s that I owned from 87 to 06, I,m sure the kx is a single ring too. The skirt- bottom of the piston has a full length-same length skirt. A  top engine builder will tell ya to run a gp piston. The gp piston is heavier than a stock or pro lite piston, just so ya know. Alot more durable tho, just get the gp piston designed for your RM, I don,t think you want to run a diff. rod just to change the piston and run the bill up to 2,400 plus.
Wiseco GP pistons?
« Reply #12 on: June 16, 2012, 10:25:51 PM »
Rod 110mm or 115mm $90
Piston $120
Rebuild crank $50
total $260
Where does the other $2k come from?
Piston cooling is what makes a piston durable.
Wiseco GP pistons?
« Reply #13 on: June 17, 2012, 01:19:22 AM »
Well, it may not matter anyway.
I lost track of the the hours on the piston that's in there (hurt and hardly riding the last 2 years), so I was going to change it and found the GP on ebay. It's about what I would pay for a pro lite at my local shop, hence the questions. I have 2 races left for the RM in this series. One is a 1 hour motocross, and the other is a regular 2 x 20 minute. I was going to buy a Husky and sell the RM. so I was being careful. The Husky sold before I got to it, then I came to my senses. I've spent 5 years making this bike the way I want. Why would I start all over again, now that I'm getting fast on it? After the next race there's a gap, so I'll probably spring for an Eric Gorr 144, porting, and fatty pipe.
I can always buy another Husky and sell the KDX  :P
