Author Topic: Do I need race fuel?  (Read 25775 times)
Offline wysguy
    • MX Track Info
« on: May 25, 2011, 10:10:04 AM »
I have a 2006 YZ250 and have been riding it for a couple months.  It seems to run well, but I am coming from 3 previous 4 stroke bikes so I am not well versed in 2 stroke performance.
Two other riders that I know that have quite a bit more knowledge than me on 2 strokes say that they went through pistons within 5 hours on their YZ250's because they weren't running high enough octane fuel (race fuel).  They both said they ran premium but recommended that if I continue to ride/race my YZ that I run race fuel, or at a minimum blend it with premium gasoline.
This seems like a huge distraction for me as race fuel isn't immediately available, not to mention expensive.
Maybe some background is helpful; I ride 2 -3 days a week all MX tracks.  I race monthly in C and Vet classes, so nothing too fast, but still competitive.  I am mechanically inclined, I rebuilt the top ends' of my 4 strokes in the past and am not afraid of rebuilding my 2 stroke now.
The bike runs well, the spark plug tells me the jetting is reasonable.  I currently use Sunoco 93 octane with 32:1 S2 oil.  I haven't pulled the head to look at the piston, but plan on doing that in the near future.  I do however notice some odd sounds from my YZ but because I am not used to 2 strokes they may be normal.  I cannot tell if it is detonation or just "2 stroke rattle".
Any advice?
Re: Do I need race fuel?
« Reply #1 on: May 25, 2011, 11:00:34 AM »
Bikes tend to last longer and happier using an octane of around 104. I buy some 108-110 and mix that 50/50 sometimes 60/40 with premium to keep it around 102-104.
Offline MXLord327
« Reply #2 on: May 25, 2011, 01:01:51 PM »
If I remember correctly, the '06 did run right on the edge of detonation with pump gas.  I think Yamaha put a different needle in the carb for '07 to cure this.  If you don't want to run race gas, check into the new needle.
Offline wysguy
    • MX Track Info
« Reply #3 on: May 25, 2011, 01:04:29 PM »
A needle change seems much simpler, and cheaper, than finding race fuel to ride.
I appreciate the advice.
Offline motomike894
« Reply #4 on: May 25, 2011, 03:01:30 PM »
Try the needle I guess but all my Rm's and my 04 and 05 Yamaha's almost always would detonate without at least running like 1 gallon 100 to 3 gallons 93, I am now running half and half, and sometimes totally race gas, but the price isnt much different.
There are 2 gas stations that sell 110 around me and its like $5.89 a gallon, hell 93 is like $4.09 a gallon right now.
« Reply #5 on: May 25, 2011, 05:55:29 PM »
I would advise against using only pump gas. Most of it is 15% Ethenol, which will gum up your carburetor and your bike will not run well. Here I can get 109 octane for just over $10/gallon and 108 for just over $8/gallon.
Offline snook620
  • weekend warrior
« Reply #6 on: May 25, 2011, 07:10:21 PM »
Every 2 stroke Ive had LOVED race gas. You can tell a defference from the minute you go to clear it out.
« Reply #7 on: May 26, 2011, 12:00:05 AM »
yep
« Reply #8 on: May 26, 2011, 05:41:44 AM »
I just found an old school gas station with non ethanol 93  ;D it's cheaper than most other places in town too. Gonna get me some of that this weekend.
As for race gas I have used it in the past on my YZ250, it needed it, my KX not so much, when I first got it, it would detonate occasionally on 93 but only if it was last weeks gas. Since I lowered the compression (with two high compression base gaskets) I haven't had a problem , the gas in it now is 3 week old 93, started it up yesterday and it ran fine.
Offline yo_marc
« Reply #9 on: May 26, 2011, 07:08:08 AM »
It's funny, here in Mass I can get away with 93 just fine.  I've had my bike (2000 RM250) detonate, but only by jetting it too lean.
I'm not sure what our ethanol content is.  I want to say 10%, but I'm not certain.
'00 RM250
'88 TRX250R
Offline VintageBlueSmoke
« Reply #10 on: May 26, 2011, 07:33:53 AM »
My advice is not to use race fuel if you can get away without it. My reasoning is this: As a Vet C rider, the performance gain from the fuel will not be worth the added expense. You would be better off saving the pennies (nickels and quarters!) and putting the money to a riding clinic or school or a new set of tires.
The caveat of course is detonation and piston life. Be sure jetting is correct and you get good fuel. SAMS CLUB or the 7-11 down the street will not have the best quality pump gas. You might pay a little more, but in the long run, it is worth it. Also, at the more expensive gas stations, you stand a better chance of finding non-alcoholic fuel.
Back when I was traveling a lot to the races, I noticed higher gas mileage in my tow vehicle if I spent the little bit extra on good gas. It always worked out in the long run.
« Reply #11 on: May 26, 2011, 07:42:43 AM »
Same here. Heck I have run 89 in my KDX before with no detonation, pinging etc. I wanted to ride and it's all I had here (I use the cheap stuff in the Craftsman tractor  :D ) so I mixed it up and it ran fine. I do not race, but I ride hard.
Offline wysguy
    • MX Track Info
« Reply #12 on: May 26, 2011, 08:44:47 AM »
Not to sound ignorant, but how do you tell which gas stations sell good fuel?  I chose Sunoco because of word of mouth.
And yes, I have no need for the performance gain, the YZ250 is plenty of bike for me and the class(es) I race.  I just wanted to treat it properly so it won't fail prematurely.
Thanks
Offline wysguy
    • MX Track Info
« Reply #13 on: May 26, 2011, 08:48:28 AM »
Last night I decided to pull the head off just to have a look at the cylinder.  I could see no signs of damage from detonation, and I would suspect the jetting to be a bit rich although the plug likes just about right.
I am going to do a little scouting around to see if I can find a local station with race fuel as it is not a matter of the expense but more of the hassle to always have some on hand.  I guess the 4 strokes have babied me and I am used to grabbing fuel on my way to the track.
« Reply #14 on: May 26, 2011, 09:04:46 AM »
Again, just from my experience; Mobile, Sunoco, BP, Shell, (surprisingly) Hess - the name brands. My guess is that they have more at stake than the budget operators so make their franchises live up to a higher standard.
